XS Power
vcm not working properly
Just hooked up my vcm to 3 irragis alternators with 3 xs harnesses. i followed all instructions.when i powered it up it was showing 15.1 and when i tried to adjust it it wouldnt change up or down. does anyone know why i cant change the settings.is there any way to reset it.
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
were the numbers flashing when you tried to adjust the voltage?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Yes sir i held down both buttons like the instructions said i get it to blink but when i hit the + or - it doesnt do anything
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
HAS any one ever extended the xs harness to give you different mounting options such as in the headliner
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Yup
Check with Nathan at XS on what the dip switch settings should be. Maybe one got flipped
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
The directions are brief but i checked and for 12v it says 5 only on. i mounted mine in my overhead console also. is there any way that by extending the wires ( i had my partner do it for me and he did a nice solder job and sleeve install) it mite of messed something up? plus i have it hooked up to my acc wire at my main harness does it have to be true ignition or am i ok? I value your advice hhr ed let me know
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Hey Ed, just a quick question I was wondering about. Why the difference in voltages between both displays? Alt charge and back batts? Jw
1989 Chevy Caprice Classic
350ci V8 High Performance
JVC Arsenal HU
JL XR series components
Infinity Reference 6x9s
Pioneer Premier 4-Channel
Clarion 2-Channel
Rockford Fosgate Series 1 2-Channel
Fusion 2000.1D
MTX Crossover
RF, Knu, Kicker, and Monster wiring
NVX VCW 12in. Sub **Won on here from the Sonic contest!**
*Build log coming soon!*
Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
Hi This is Ed's Girl Friend.
Extending the wires to the VCM didnt change anything since they are basically just power. Any voltage drop from a few extra feet is minimal.
But It should be on true ignition since some cars have ACC that can shut off.
The 12v setting for the VCM dip switches have a limit of how high it will go, and you may be at that limit, I am not sure what it is.
But it does take a few pushes of the arrows to get it to move, so keep pushing it.
The settings must be changed with the car running and amps turned off.
Also, for the above picture, one meter shows the rear batteries of the vehicle (20 D1400s) And the VCM meter is the alternator setting.
