speaker wiring
You don't... You hook up 4 sets max which I believe will give you a 4ohm load in series active. You need a 5 or 6 channel if you want to do 5-6 components.
Team Bassick
HU: Pioneer DEH-4200UB
Front: Pioneer TS-A1683R
Rear: Pioneer TS-T110
Amp: Kicker KX600.4
Subs: PSI 18" Platform 1
Amp: Audiopipe 1500D
Electrical: Big III, Stinger SPV-40, Stock ALT
SCORE: N/A
my bad it is 4 sets im getting rid of 1 set i would like to bridge the amp at 4 ohms it seems hifonics make more power at 4 instead of 2 ohms
my bad it is 4 sets im getting rid of 1 set i would like to bridge the amp at 4 ohms it seems hifonics make more power at 4 instead of 2 ohms the reason i want that amp is to match my 2 other hifonic amps
WRONG! That's like saying you can only hook one sub to a mono block amplifier... It just isn't right... He could run a 2 channel amp to those of he wanted to.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
  • Who's Online   0 Members, 0 Anonymous, 798 Guests (See full list)
