DVC 4ohm running of a 2 ohm mono?
Subwoofer is a DVC 4 ohm, wire the coils in parallel for a 2 ohm load.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
An example of a compatible amplifier.
http://www.sonicelectronix.com/item_9852_Rockford+Fosgate+Punch+P300-1.html
Name/brand of woofer?
EDIT: and to answer your question, yes it is safe, as long as the amplifier is 2 ohm stable.
Edited by Cardboardcat15
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
NRG Do you have the same sub? Thx!
I dont sorry i have the Pioneer TS-W 3004 SPL powered by an alpine pdx1.1000 with a secondry battery on a 100amp alternator with 4awg and recent 250amp anl fuse.
kept popping the 80amp agu's lol
friend of mine had 2 of your subs though powered by alpine mrd 605 i think it was and that was good too.
as for box making well i learned that lesson in a hurry.
i built a box to the sub specs and it was laaaaaaaaaaame. i then experimented and found that a big ported box had more boom.
lots of info on the net and especially on here about boxes, Whats to loose really as you can only learn by mistakes and i gotta admit its fun too. After some experimenting i ended up with a double the size box with a slotted port and man does it bang for what it is 8)
This will be my first box that i have made for myself and I'm expecting some mistakes to occur! lol thanks again for all the great input. i posted this question in subwoofers / enclosures but i was wondering if you guys knew if there is a difference is sound if i were to put the sub facing up in a "L ported" box compared to parallel to the port? if not. Thanks anyways!
  • Who's Online   1 Member, 0 Anonymous, 1803 Guests (See full list)
