Ground Wire Smaller than power wire
Ive been googling this for a while and I still cant find a good answer..but is it ok if I have a 4 gauge power wire and a 6 gauge ground wire for 1 day? because tommorow im getting another 4 ga ground wire from my buddy. Would it be safe for the amp/subs???
what amp are you running?
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
itll work, but do NOT turn it up. its really not a good idea.
Depends on the amp and how much power. . .if 6ga can handle the current with acceptable voltage drop for the length of wire, it is fine. If it causes the voltage to float up due to the drop across the wire, it is not good. This really applies to any ground wire - even if it is the same size as the power wire.
Current system:
Previous systems:
It will be fine. With that amp you could just leave it that way. 6 ga is large enough.
Current system:
Previous systems:
Just FYI, wire size is based on more than just wattage.
It is based on heat rise and the amount of voltage drop that is acceptable in your application.
Different wire of the same ga can have different resistance per foot which changes the voltage drop with a given current and the amount of heat generated.
The length of the wire changes voltage drop.
The type of insulation determines how much heat rise is acceptable.
And the list goes on. . .
Current system:
Previous systems:
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
