I asked on another site awhile back how to hook up more than one amp if your HU only has one set of amp outputs and someone said use something like this
I was just curious if you guys suggest doing this or if you have better techniques
My professional opinion and how I do it is:
Buy some sort of Eq, or signal processor that will accept 1 set of preouts in, and output 3 or more preouts out.
My reason behind the need of the EQ or Processor is due to the fact that if your headunit only has 1 set of amp preouts, or no preouts at all and you are using a hi/lo output converter attached to your speaker wires your input signal to your amplifier(s) is 100% crap in most cases. You will have a low preout voltage and a very unbalanced input signal which is distorted to hell and back.
Some links to some things that would be good examples.
EQ's:
Pioneer deq-9200
http://www.sonicelectronix.com/item_772_Pioneer+DEQ-9200.html
Pioneer deq-7600
http://www.sonicelectronix.com/item_771_Pioneer+DEQ-7600.html
Kicker KQ9
http://www.sonicelectronix.com/item_520_Kicker+KQ9+-03KQ9-.html
AudioControl EQX
http://www.sonicelectronix.com/item_7993_AudioControl+EQX+-COLOR-+GRAY-.html
Processors:
MTX ReQ
http://www.sonicelectronix.com/item_9855_MTX+Audio+re-Q+-REQ-.html
MTX ReQ-5
http://www.sonicelectronix.com/item_10834_MTX+Audio+reQ-5+-re-Q+%3Csup%3E5%3C-sup%3E-.html
Rockford Fosgate 3sixty.2
http://www.sonicelectronix.com/item_7148_Rockford+Fosgate+3SIXTY.2+-UPC+-780687322953-.html
Or browse for other cheaper end units that will still offer you 3 sets of pre outputs from only 1 set of input.
http://www.sonicelectronix.com/cat_i20_sound-processors.html
Either way, a EQ or Processor will clean your input signal, it will boost your preout signal (like a line driver), you will gain more preouts without Y cables that drastically reduce your already weak output voltages, and gives you abilities to shape your sound system frequencies to those you like by having a higher band eq then your low end headunit or factory radio.
So I think this post deserves the /thread award.
PS: Logan, while the maxx-link is decent at running multiple sub stage amplfiers it is completely useless for other amps used for the mids and high portions of your radio, and they dont last too long.. I need to order my 4th one here pretty soon..... I keep rattling them to death and having the rca output cups fall off. :(
Edited by Audiofanaticz
post/thread award given...... :clapping:
that first pioneer was sick!
my alpine has 3 preamp outputs. sub goes into the first 2610, and back out to the other 2610. then used y splitters from front rca to 1 6410 4 channel, and the same for the rear rca to the other 6410
I think I still need a processor........................
Edited by 98crewcab
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
