I asked on another site awhile back how to hook up more than one amp if your HU only has one set of amp outputs and someone said use something like this
http://www.google.com/products/catalog?q=rca+y+adapter&hl=en&cid=13504841509383046859&ei=ZGWUTIOTE5D0MKSPzZUO&sa=title&ved=0CEEQ8wIwBDgA#p
I was just curious if you guys suggest doing this or if you have better techniques
1993 Cadillac Fleetwood Brougham.
Jensen UV10 DVD HU
Two 12" Sony Xplode (temporary)
what kind of amps?
what kind of amps?
Nothing specific, just assuming they are ones without outputs on them.
Jensen UV10 DVD HU
Line out converter works for OEM interface.
Y adapters for connecting multiple amps work, but best results are with a Line driver.
OR Just buy amps with In/Out RCAs
thx, my technical english could be better, that is what i ment.
"in the abundance of water, the fool is thirsty" Bob Marley
I got to amps. Here's how it's setup.
Ok so correct me if Im wrong, it looks like you are using an adapter like what I linked, or is that the line driver at the bottom of the pic?
Jensen UV10 DVD HU
