SLG Posted September 19, 2010 Report Posted September 19, 2010 hi, i got a 79 cutlass ive been working on, it was in an accident then sat for 10 years and got extremly rusty. i fix the front of the car that was in the accident, but the back half of the car is rusty. the surface rust came off good from just sanding it to bare metal. theres a lot of rust that i cant seem to get up though. i started on on the trunk, all the surface rust came up, but in some parts the metal is black(idk what thats called), and i cant sand that off. I was using 150 but it wasnt doing much of anything so then i started using 100 and it did seem to help get it off much, any ideas? heres some pic so u can get a better idea of what im working with: car sat like this for 10 years in the sun: After I fixed the front a month ago mysef (ready to get a real paint job, thats just my prime spray paint job temporarily, lol) All the rust im trying to remove (other side of car still looks good with no rust for some reason, idk) any ideas on how to get this off easier would be nice, kinda sick of sanding for hours with not much of results Quote 2008 Dodge Ram 1500 Quad Cab - Pioneer AVIC-Z110BT - Rockford Fosgate T1500-1 - Probox 2 10's - Rockford Fosgate T600-4 - 3 sets of Rockford Fosgate T2652-S's 1968 VW Bug 1914cc
teknikalitch Posted September 19, 2010 Report Posted September 19, 2010 go rent a sandblaster... or get nasty with a really low grit. Quote 1992 Honda Accord LX Head Unit: Alpine X-001 Mids/Highs Front: Rockford Fosgate P1652-S Components Mids/Highs Rear: Rockford Fosgate P1653 3-Ways Mids/Highs Amp: Hifonics Zxi6410 Sub: Fi 15" BTL With HiXmCoil Option Sub Amp: Hifonics Bxi2008D Enclosure: 5.2Cubes Gross Tuned at 31Hz Wiring: One Run Of 0g Alternator: Load Boss 170amp
TeejayBee Posted September 19, 2010 Report Posted September 19, 2010 (edited) get like .80 grit then get higher or get a grinder Edited September 19, 2010 by TeejayBee Quote
bassHZ Posted September 19, 2010 Report Posted September 19, 2010 (edited) i would say just get a another trunk lid from the junk yard and for the rust i dont know how to fix that but i do know that u have to use epoxy primer so the rust wont come back i learned that the hard way so dont go cheap when ur gonna DIY cuz u will end up spending double just my opinion o and by the way nice A body would like to see it when its all fixed up Edited September 19, 2010 by jl_audio Quote
Skullz Posted September 19, 2010 Report Posted September 19, 2010 Media blasting is the only way to saved the metal thats left from all the rust and hope it hasn't penetrated to a point where you need to replace those parts with ones cut from another car. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
blackrosetiger Posted September 19, 2010 Report Posted September 19, 2010 go rent a sandblaster... or get nasty with a really low grit. do NOT get a sand blaster instead use a soda blaster its much much easier and doesnt pit like a sand blaster will. Its what I used on my 68 cutless and made my life so much easier. Quote 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
mbdblue Posted September 19, 2010 Report Posted September 19, 2010 it would be easier if we saw pics of what it looks like now. and if your going down to bare metal anyway, you can go all the way down to 40 grit if you want to, just dont use it on a grinder. some of those pieces may need to be cut out and replaced. Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Skullz Posted September 19, 2010 Report Posted September 19, 2010 DO NOT sand or sandblast the car as your only removing metal and thats the last thing you want to do, take it and pay someone to media blast it as it will actually look like new and smooth the metal vs. pitting it with sand paper and sandblasting. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
mbdblue Posted September 19, 2010 Report Posted September 19, 2010 (edited) DO NOT sand or sandblast the car as your only removing metal and thats the last thing you want to do, take it and pay someone to media blast it as it will actually look like new and smooth the metal vs. pitting it with sand paper and sandblasting. sanding (on a block) removes such little metal that it wouldnt matter. you dont need just a media blaster to do this kind of work. and most likely, pitting the metal will be the least of his problems when everything gets cleared up. the metal is already pitted like hell from the rust thats eating through it. you make it sound like sanding would be the worst thing in the world and media blasting is his only option. while media blasting is probably the best option, it IS NOT the only one. and no it will not always look like new. it depends how far down the rust has eaten. he might end up with back panels that look like swiss cheese anyway. Edited September 19, 2010 by mbdblue Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Skullz Posted September 19, 2010 Report Posted September 19, 2010 (edited) I'm trying to say its the only method he has but one that would yield the best results and leave little work after the process to prep for painting. Edited September 19, 2010 by Skullz Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
