I'm planning on painting my dash in my 2005 GMC Sierra and as I'm sure you know just like Steve's dash the trim panel has those grooves in it on both sides so I tried filling them with Bondo and after all the sanding, priming, and clear coating the Bondo is starting to pop out of the grooves on its own. Any suggestions?
2005 GMC Sierra Ext Cab
Optima RedTop Battery
Alpine CDE-9874 Head Unit
2 Rockford Fosgate T1 12's
1 Rockford Fosgate T500-1bd Amp
4 Rockford Fosgate Power Series Coaxials (Factory Sizes)
trying to do this?
flex filler from urethane supply.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks... I was wondering about that as well... This is exactly what it needs... YOU ROCK!!!
maybe someday ill actually finish that piece too.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
trying to do this?
Yep exactly what I'm tryin to do I just couldn't get my paint to look as smooth and the Bondo is popping out. Of course I didn't use any adhesion promotor and it probli would have been better to use that special interior paint.
no adhesion promoter there.
sand with 120.
sanded with 220
wetsand with 320
primer
primer
primer
wetsand with 320
primer
primer
primer
wetsand wtih 600
Its not that shiny normally but it is smooth. That was still wet on one of the umpteenth coats of primer. I'm going to base it with some silver and then red over it.
ive got my overhead console apart to paint and ill be starting my door handle trim pieces as well. probably some other stuff too but im sure you can imagine how much work is in it
oh yeah thats all rattle can too. :ehh:
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah I plan on doin all the plastic on the interior. And did mine with rattle can too. It probli wouldn't be that bad if I sanded it and put more paint. Did you clear coat yours? Cuz I got the paint smooth and after the clear coat it was fucked up again. I'm probli gonna sand everything off and use the real spray gun on the air compressor. That'll probli give me a lot better finish.
no celar coat on that yet. once its painted it will get the claear.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah I'm just gonna sand mine down redo the bondo and hit it with the spray gun instead of the rattle cans. And car quest mixes interior paint so i'll get it there. A guy at an auto body shop told me interior paint has a certain sheen to it that makes it better.
  • Who's Online   0 Members, 0 Anonymous, 2243 Guests (See full list)
