wiring 100 drivers
Ok i've got it and i know what this project is too :P.
Wire 5 drivers together in parallel (.8 ohms). Make 5 sets of those. Then series the 5 sets (.8 + .8 + .8 + .8 + .8 = 4ohms) and you get a final ohm load of 4 ohm per 25 drivers. On lets say a 4ch amp which gives you 100 drivers, 25 per channel at 4ohm per channel.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
This is literally exactly what Ed said. And thats the plan with the pyle amp. Tweets are coming after tax return and hopefully new amp before that.
And boon, tbh... i have no idea what it is. Thats why i ask the smart people :peepwall:
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
yeah man what is rise? haha
i think basically it is once you start moving it the resistance increases?
talkin out my ass tho...
someone explain?
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
and man, 100 drivers? whats goin on over there? haha
ty
TY
yep.....:)
Tax return? Jeez you've got a long time to save. Where are you putting these? And does your amp crossover high enough for tweeters?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Yeah, its gonna cost 3-4 hundred to do both doors. And i plan on glassing in either pvc pipe or exhaust tubing into the door panel so i can remove them and replace them really easily. I think the amp that i have and am using does have a crossover that should work, and i don't think it puts out enough power to blow them anyway. This is gonna prove to be a try it and see type thing.
Tercel build R.I.P.
V-Dub
My feedback.
Damn, I hope you make a build log because ill be a subscriber (along with many other people)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I'd go a bit higher than 4 if you can.
Rise is the upper fluctuation level of your active variable resistive load (its the maximum excursion level of the coil in the magnetic gap).. say you attach a 1 ohm driver to an amp. It will have a high and a low peak. If you want to use "rise" to make more power you do it for burps in SPL. You dont do it for daily.
Given the number of drivers you are using i'd maybe shoot for a bit higher than 4 ohms, though technically tweeters dont fluctuate their resistive value as bad as a subwoofer with a coil that jumps around in the gap a lot I guess.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
