power wire close to exhaust?
im going to wire up my XSd3400 up front with my D3100 in parallel in the rear but i want to run it under the truck but on the passanger side where i was goin to run it is pretty close to my exhaust
i can run it and it wont be touching the exhaust but it will be near it
if i wire loom it or something would it be ok or should i not risk it?? i dont want my wire melting on me lol
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
im not 100% sure but i would guess that 3"-4" of clearance should keep you in the clear.
best bet would be to run it thought the fire wall to keep it from being exposed to the elements. I have seen a threat though where people used PVC under the car and ran the cable through that to protect it. May be something to look into. Not too sure though, i have never ran cable under the car/truck
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
ya the pvc method is very good. unless you can really tuck it away under something.
zip tie it too your heater hoses then pull it close to the inner fender well then i run it on top of my frame theres enough room for 3 0gs, i went back past the catilytic convertor the crossed back over to the inside about where your rear doors will be then came up behind my rear passenger seat
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1499 Guests (See full list)
