no picture. but I went to get my new setup done today. peaked at the battery under the hood. and It was like snow. The negative terminal was completely white. what should I do here? it is so corroded that the terminal and the negative post itself are almost fused together. Doesn't look safe. I have a xs power d925, should I just drop the stock battery in the hood and replace it w/ the d925? it says the xs d925 "Can be used as the main battery and still provide power for amplifiers up to 1000 watts!"
so what should I do here?
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
oh and I'm running a 1000w mono amp for my 15" fi bl so.. would that idea work? and would the corrosion happen again? anyone know the cause of it?
2004 Volkswagen GLI
1 10" Skar VVX
sorry if it wasn't clear. the battery under the hood is the stock battery, I was gonna wire up the d925 in the trunk today but the negative post on the stock battery scared me enough to not do anything lol
2004 Volkswagen GLI
1 10" Skar VVX
get a new or second battery and your avatar makes me hard:)
Someone correct me if Im wrong, but isnt the corrosion caused from the different types of metal having current going through them?
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
i dont think we needed to know that.
Nah its typical sometimes. Just clean it off with some chemical from an autoparts store hose it down and youll be fine. Just be sure to cover it with grease when your done so it doesn't happen again. If the terminal fails (for some odd reason) then ehh your out 4 dollars for a new one.
That and several other reasons.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
baking soda and water will clean it off with no problem.
EDIT: If you want to keep that battery and add a second one for the time being glue a copper penny to the battery between the positive and negative posts to keep from getting corrosion.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
