how do you test impedance rise and how do you combat it?
Alpine F1 Status
DD CS6.5 x2 Front Stage
DD 9512H
DD M4a @ 2 ohm
DD S2b @ 8 ohm per channel
I run high ohn loads for MASSIVE headroom and cleaner SQ
270amp alt
D2400 up front
D3100 x2 batter in back
You need a clamp meter to calculate it. Clamp the power comin out of your amp, from that you can calculate your total impedance. Subtract your nominal impedance, and you have box rise. How do you fight it? Build another box, then another one, then another one, then a couple more, and see which one has the least rise.
Sigh* Just waiting for Boon to chime in.
Haha..you beat me to it
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Well, i suggest you not to clamp your system, you are gonna get all sad hahhaa, clamping results for daily boxes makes you wanna cry, you have a 3500 watts giving you about 2000 real watts if you are lucky, makes you wanna kick yourself on the head! :angry:
This is so true, when I clamped my 2200d I was only getting 450 watts. It was comforting though to know it was doing rated power at that ohm load(4.5 ohms) and I'm doing pretty good numbers for such little power
TDH FTW !!!
yeah, same happened to me with my Cadence C6, 6000 watts @ 1 ohm 16v specs, i had 13v and final impedance was 3.8 ohms, did 2800 watts wich was more than fine for 16v amp at 4 ohms, but it was very sad haha, if you are building a burping machine yes you need to know your real impedance, for daily, i wouldn´t even worry about it :peepwall:
Thisvis interesting. I've seen posts where claims of larger 45svin enclosures spike the rise.
Are there any conditions to avoid?
I'm off to get bigger amps!!!
Alpine F1 Status
DD 9512H
DD M4a @ 2 ohm
270amp alt
D2400 up front
