Carroot1 Posted September 29, 2010 Report Posted September 29, 2010 I have 2 12 inch Sundown's and a AQ1200D which says it produces 1200 rms at 14.4v but my battery is a 12v battery, will a cheap 2nd battery do the trick or not? The big 3 is impractical for me since my battery is in the trunk (German Engineering) My cars a bmw 323i 1999 Thanks MY amp http://www.audioque.com/aq/?page_id=26 Quote
Tek Posted September 29, 2010 Report Posted September 29, 2010 ehh a 12V battery will put out 14.4 volts. With that amp, I don't see how you will get the full 1200 volts, but as impractical as you think the Big 3 is, you need to really consider it if you want your set up to put out more power. Another battery will help, but you should do the Big 3 first and foremost. Quote
Carroot1 Posted September 29, 2010 Author Report Posted September 29, 2010 ehh a 12V battery will put out 14.4 volts. With that amp, I don't see how you will get the full 1200 volts, but as impractical as you think the Big 3 is, you need to really consider it if you want your set up to put out more power. Another battery will help, but you should do the Big 3 first and foremost. my problem with the big 3 is how the hell will i get my wire to the alt when the battery is in the back? Quote
hdorre Posted September 29, 2010 Report Posted September 29, 2010 (edited) Uhm, doing a very long run Edit: to answer your original question, it depends what batteries you're using because I've read that it isn't good to mix batteries Edited September 29, 2010 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Skullz Posted September 29, 2010 Report Posted September 29, 2010 Providing the dimensions are the same this is a great battery to replace your stock one with and yes the big 3 will make a big improvement and adding a second battery will increase your capacity. http://www.autobarn.net/eas9agm49.html Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Carroot1 Posted September 29, 2010 Author Report Posted September 29, 2010 Providing the dimensions are the same this is a great battery to replace your stock one with and yes the big 3 will make a big improvement and adding a second battery will increase your capacity. http://www.autobarn.net/eas9agm49.html my stock battery is much bigger than normal car batteries but i have room for another battery under the hood Quote
Tek Posted September 29, 2010 Report Posted September 29, 2010 you just need to do the long run of 1/0 and do the Big 3 Quote
Carroot1 Posted September 29, 2010 Author Report Posted September 29, 2010 Uhm, doing a very long run Edit: to answer your original question, it depends what batteries you're using because I've read that it isn't good to mix batteries under the car? Quote
Tek Posted September 29, 2010 Report Posted September 29, 2010 under the car? either that or under the carpet, whatever floats your boat. I haven't ran wires under my car before, I dont trust myself cutting. I do know that you should use PVC piping to protect the wires. Quote
Boon Posted September 29, 2010 Report Posted September 29, 2010 Don't worry about the Big 3 in a BMW. Just upgrade the chassis ground to a short-ass piece of 0ga to one of the frame rails right beside the battery. We ran like 5kw off a single big battery in the trunk of a BMW 5 series, no problems at all. Quote 10.x volts fo' life!
