Robert8252 Posted September 29, 2010 Report Share Posted September 29, 2010 Honestly you can connect it anywhere you want. On the amp is technically the best but voltage in you car from front to back isn't going to be very different no matter where. If voltage is dropping at your amp it is dropping at you front battery and your cigerette lighter. So what ever is easiest for you. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
pheint_1 Posted September 29, 2010 Report Share Posted September 29, 2010 (edited) i think I've read that most people like to know the voltage at the amp/s so i would say wire it there. edit: Edited September 29, 2010 by pheint_1 Quote Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 29, 2010 Report Share Posted September 29, 2010 (edited) Im half blown retarted. so just rite in the + and - of the amp. im also going to be running a high amp. so i was thinking the back batt. connect it to the sub amp, that is where you want the voltage to be correct. there should be some sort of turn on wire for the voltage meter also, with the + and - Honestly you can connect it anywhere you want. On the amp is technically the best but voltage in you car from front to back isn't going to be very different no matter where. If voltage is dropping at your amp it is dropping at you front battery and your cigerette lighter. So what ever is easiest for you. That is not always true. you could have bad connections on your amp, bad wire, etc. that give you different voltages at different spots in the car. Edited September 29, 2010 by shkibbybop Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
pheint_1 Posted September 29, 2010 Report Share Posted September 29, 2010 either connect the remote on your ignition or just wire it on your amp as well. Quote Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela. Link to comment Share on other sites More sharing options...
Boon Posted September 29, 2010 Report Share Posted September 29, 2010 And don't forget to calibrate it with a DMM, wherever you put it... Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
