where do you connet a volt meter. front batt. or back batt. or a 12 volt sorce like a cigeratte lighter. my cosint said the 12 volt sorce. to read the over all voltage.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
who cares what your voltage is on your cigarette lighter. The voltage you are worried about it what your amps are seeing. Connect your voltage meter close to your amps.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
If you have a sub amp I would suggest connecting it to that. That way you can check the voltage it's seeing
x2 thats where i got mine at
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Im half blown retarted. so just rite in the + and - of the amp. im also going to be running a high amp. so i was thinking the back batt.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
red to positive blue to remote black to ground on your amp, you're welcome
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
