the atomic lumina-2 atomic apxx 15s walled
some updates for y'all
i finally got off my ass and ran me some number 4 wire going to some bolt connectors at rear for easy imp change
i soldered up the ends for easy insertion to sub terminals
and the sexy sub looking all lonely :(
R.I.P!
(Nov-29-2009)
92 explorer
current build
pretty cool how you can easily change the impedance, but why use 4 gauge for speaker wire? especially for such a short run, 8 or 10 gauge would be plenty? 2nd, if your so worried about loosing power through the speaker wire, why add ring terminals and bolts and such? it only adds resistance. I'm not trying to bash, just trying to learn since what you did goes against what i have learned so far
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
because the wire was 1 dollar a foot or so... figured it was cheaper going that rout
im not to worried bout all that resistance n blah blah shit i just wanted to be able to drop it to .5 for when i need that extra little bit power
R.I.P!
(Nov-29-2009)
92 explorer
current build
R.I.P!
(Nov-29-2009)
92 explorer
current build
:drink40::popcorn:
we got it all installed didnt get pics of wires cause there ugly and were a rush job
went on a long drive today and blasted it and holy fuck it gets loud like nasty loud and loves dubstep haha
i'm trying get everything lined up with the hair trick lady and see what i can get on video
R.I.P!
(Nov-29-2009)
92 explorer
current build
work from yesterday
made some brackets
a t nut and bolt
welded up a washer and nut
ended up having to weld on a coathanger and cut off a corner
now i know you cant really see it but i had drilled 2 holes from uptop and they ended up being in frame rail which is why i used coathanger
then i bolted it all up
and now i gottta rip box out take sub out and mount the T nuts inside the box
oh also found broken screw on amp foot so gotta replace that
R.I.P!
(Nov-29-2009)
92 explorer
current build
got some tnuts mounted in the box and mounted to angle iron brackets that box aint going no where
yes the noodles have gone back in
used some bigger screws to hep from breaking off
R.I.P!
(Nov-29-2009)
92 explorer
current build
