the atomic lumina-2 atomic apxx 15s walled
got the wire for speakers all bolted up
failed template
failed test piece
made some templates out of a quiznos sign i had layin around
got them in still need glass them in
now im thinking of putting 2 sets 6.5s here
OR
put them up top and throw in 4 8"S in the sides and do a 3 way setup
i have 2 sets of 6.5" bassworxx comps 4 8" elemental designs E8s and 1 set of 5.25 bassworx comps to use up in this build
i plan on running the 2 6.5s on per channel on the C4 and then have the 5.25"s on other channels
and i got an alpine 250 watt 2 channel amp to run the tweeters on
R.I.P!
(Nov-29-2009)
92 explorer
current build
I bet you squat a little huh
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
haha i dont quite follow N8
R.I.P!
(Nov-29-2009)
92 explorer
current build
As int he ass end is barely above the tires.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Dur makes sense now...at the moment shes bit low but once i throw the subs in and amp(s) she'll be down on tires haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
got some work done today got the top pieces in place for now
made cut templates using same quiznos sign
then cut it out of wood
from behind i still need mount to the box (looking for ideas)
and the gaps i need to glass to seal off the front cabin
R.I.P!
(Nov-29-2009)
92 explorer
current build
Nice work. Expecially considering that you are recycling materials.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
thanks man... i wish i could get more done and have more updates but im at a standstill untill i get the back window tinted (i've never tinted before and wanna order pre-cut tint but thats going take over week+ to deliver) then i can get the wall glassed up and call er done
R.I.P!
(Nov-29-2009)
92 explorer
current build
