i have a 105 amp stock alt and im prolly going to be running a audioque 2200d or a saz 3000 ive been told 2 xs power d3400's will be good enough is this too much for the stock alt or the 2 extra batterys will do the job
Setup:
Headunit: 7" indash screen
Sub: fi bl 12
Amp: Audioque 1200D
Box Ported tuned to 34hz
Big 3 done in 1/0 gauge
I did 3k 105amp alt with 2 stinger spv35 and a kinetik hc2400, driving I'd see 11s almost instantly... 10s at idle... took about 30minutes of playing the new system to realize I needed an alt.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
So i wonder about a 220 amp iraggi alt and i got a big battery up fronts its a semi battery then in future add a xs 3400
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
If you wanna run 3k and be able to play it full tilt for more than 30sec-1min then get an alt... Go with the biggest you can get for your car, that's what I did, then you never need to upgrade... well useless you go duals lol...
Like Chris said I'd choose another brand. I like Dc Mechman is good too.
I know Rob at DC has helped me out and hooked me up.
Edited by wL<3bass
My YouTube Videos
what would i need battery wise. and you know a site where theres dc alts ive heard good things bout them put couldnt find anything about them
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
text doms cellphone i just got ahold of him a few days ago. and his 220 is a great alternator. works awesome for me and cheaper than dc and mechman. plus any color you want.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 588 Guests (See full list)
