i have a 105 amp stock alt and im prolly going to be running a audioque 2200d or a saz 3000 ive been told 2 xs power d3400's will be good enough is this too much for the stock alt or the 2 extra batterys will do the job
Setup:
Headunit: 7" indash screen
Sub: fi bl 12
Amp: Audioque 1200D
Box Ported tuned to 34hz
Big 3 done in 1/0 gauge
I did 3k 105amp alt with 2 stinger spv35 and a kinetik hc2400, driving I'd see 11s almost instantly... 10s at idle... took about 30minutes of playing the new system to realize I needed an alt.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
So i wonder about a 220 amp iraggi alt and i got a big battery up fronts its a semi battery then in future add a xs 3400
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
If you wanna run 3k and be able to play it full tilt for more than 30sec-1min then get an alt... Go with the biggest you can get for your car, that's what I did, then you never need to upgrade... well useless you go duals lol...
Like Chris said I'd choose another brand. I like Dc Mechman is good too.
I know Rob at DC has helped me out and hooked me up.
Edited by wL<3bass
My YouTube Videos
what would i need battery wise. and you know a site where theres dc alts ive heard good things bout them put couldnt find anything about them
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
text doms cellphone i just got ahold of him a few days ago. and his 220 is a great alternator. works awesome for me and cheaper than dc and mechman. plus any color you want.
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1117 Guests (See full list)
