So I need to wire to ~2ohm total load for each amp to see 1 ohm. I really appreciate you guys trying to help, this is my first experience with strapping amps and I don't want to fry something or void my warranty. VC's parallel/subs series, like so http://images.the12volt.com/12voltimages/3_1ohm_dvc_1.5ohm.gif
SMD Super Seller
My Feedback Thread
ok so ive never done parallel/series wiring configs but i gave it a shot
1.4x3=4.2/2 = 2.1/2 = 1.05 load each amp
:shrug: damn man im trying to help but im not really sure if im right lol
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
You're better at the math than me, hopefully someone will chime in and confirm/deny what you got.
SMD Super Seller
My Feedback Thread
Are they 1.4 ohm, or is that the DC resistance???
Get dual 2's, series the coils on each sub (4 ohms), parallel the three subs for 1.33 ohms. Each amp sees 0.67 ohms. No problem for those amps.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I've already got the subs, 1.4 vc. Reading 1.7-1.8 on the DMM.
So should I http://images.the12volt.com/12voltimages/3_1ohm_dvc_067ohm.gif
or
SMD Super Seller
My Feedback Thread
this one
3- 1.4 subs puts you at 2.8 when wired in series thendivide that by 3 you get.933 that is the ohm load at amp then when you strapp them they see half of that so .46 as long as you have electrical you should be fine, i have my ddm4s at .35 and they play music all day but they will protect at 30hz and below if im railing on it. cause my imped drops when the box unloads all its air at least thats my theory
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
