CruelSoul Posted October 4, 2010 Report Posted October 4, 2010 I bought 2 used memphis power reference 10s in a box I dont know what the ohms are and they make 2 different kinds of the subs so how can i figure out my subs ohms to wirem?
slim2fattycake Posted October 4, 2010 Report Posted October 4, 2010 get a dmm and check the resistance on them. SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
Guest Posted October 4, 2010 Report Posted October 4, 2010 get a dmm and check the resistance on them. Pretty much. Mind you they will never read a perfect number. Example a 4 ohm woofers will most likely read somewhere around 3 to 4 ohms. It's generally not higher than what it says. Like 5 ohms for a 4 ohm woofer. If it reads something crazy high then its blown or close to being blown
TeamHT Posted October 4, 2010 Report Posted October 4, 2010 um....i could have sworn that there was only the 4 ohm power reference. only difference being one is a SVC and the other is DVC Tell me...does this smell like chloroform to you?
OrionStang Posted October 4, 2010 Report Posted October 4, 2010 Pretty much. Mind you they will never read a perfect number. Example a 4 ohm woofers will most likely read somewhere around 3 to 4 ohms. It's generally not higher than what it says. Like 5 ohms for a 4 ohm woofer. If it reads something crazy high then its blown or close to being blown I think you're backwards. My 1.4 ohm coils read 1.7-1.9 between 3 subs.You have to account for the resistance of the dmm leads, which you can determine by touching the leads to eachother. SMD Super Seller My Feedback Thread
CruelSoul Posted October 5, 2010 Author Report Posted October 5, 2010 heres the thing i wired to 1 ohm pos to pos neg to neg on each sub then went pos to neg etc and with my amp its 1 ohm stable when i crank it up its cuts out everytime and dunno why its a kicker kx1200.1 but if i play it on 1 sub it doesnt cut out and then i started blowing fuses to now any suggestions?
TeamHT Posted October 5, 2010 Report Posted October 5, 2010 well....im in a hurry, but those amps are not 1 ohm stable. i think youre confusing the .1 for 1 ohm when it means 1 channel. when wiring 1 sub youre running it at 2 ohms, which the amp is stable at. wiring both subs in your configuration wires to 1 ohm which the amp is not stable at. and i believe the 1200 was max ratings on the kx series. only 600watts rms Tell me...does this smell like chloroform to you?
TeamHT Posted October 5, 2010 Report Posted October 5, 2010 wiring diagram by 12volts Tell me...does this smell like chloroform to you?
