well i just got my car towed back to my house a few hours ago. got it taken apart ( acc belts, timing cover. ect. and got the top driver side mount off. and the bolt holding the mount to the block came out and completely stripped the threads. and the lower bolt of the mount is half exposed from a piece of aluminum on the block breaking off due to harsh shifting. so i need to know how to fix the issue with either helicoils or what. i will post pictures as soon as i can get them. they'll be alot of help describing what im talking about.
Edited by cmamtower
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
waiting on wilson aka wL<3bass to upload. i think he's working and i dont have a camera. but i guess i can look for my old phone and take some pictures with that.
Enclosure: n/a : (
Subwoofers: n/a : (
ok picture time lol
heres the block itself, the top and bottom(broken) holes are where the mount itself screws in.
heres the mount
heres my molested car lol
and heres how my bumper is being kept from cracking anymore
Enclosure: n/a : (
Subwoofers: n/a : (
the only way that could have happened from "harsh shifting" is if the bolts were not tight in the first place. someone fucked something up some time in that cars life and it was just a ticking time bomb.
that is the mount on the drivers side correct?
yeah its on drivers side. and about a month ago the bottom one broke and i picked out the chunk and tightened the bolts down back in. the bottom one would actually tighten as well. driven it like a grandma since then. not sure how the motor pulled to the side and stripped both bolts out though.
Enclosure: n/a : (
Subwoofers: n/a : (
i also have a spare block i can swap over but thats my very very last resort.
Enclosure: n/a : (
Subwoofers: n/a : (
the solution a new grade 8 bolt and a tap and die set Tap & Die
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
yeah, but what about the bottom hole? it has a huge chunk missing from the bottom. i could always drill out the center one and tap it as well and somehow weld the bottom one back into somewhat factory form and retap it? so instead of having 2 bolts holding it on, i'll have 3.
edit: i only need to use this motor this winter, im swaping it in january when i get my check for school
Edited by cmamtower
Enclosure: n/a : (
Subwoofers: n/a : (
bigger bolts and make new threads with a tap. next time tighten the bolts or get the right ones. that would be the old reason why they did that.
2015 silverado crew cab
nothing atm but soon...
