Man I just hooked up a p550.2 (around 600rms) goodness rockford power is so powerful for what little power the amp I have is...wish I could witness :blink: the 30,000 rms you are getting from that suv! Have you ever benched those amps yourself steve?
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Follow my Tweet (Twitter)
Posted Image
Time for some plumbing.....a trip to Homedepot took care of the fittings. I had 4 of the T fittings on hand already so that worked great. This is where i add the pressure sensors to each bag. It will all make sense later. I also had to spend some qualty time in my chair teflon taping all these things.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Time to start wiring up the front "level" and pressure sensors. First thing i had to do was make sense of it all. i had to "un loom", cut and trim all these as well. I dont want a big "bow" ziptied under the car somewhere so its all cut to exact length. I soldered, heat shrunk and put it back in the loom...worked out great!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
All that raw wire that you saw was put back into the loom that i had left over when i cut the slack off. Its perfect legnth and it still looks factory :D
Posted Image
Posted Image
Its in a critical area so i figured i would double ziptie it here. Also the wire for the driver side is ran beside these and it heads under the radiator and pops out right where it needs to be......then same thing, cut, solder, heat shrink, re-loom........done.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
A shot of the finished product......new plumbing, new wiring......
Posted Image
I almost called it quits for the night but i decided to raise it up and take the back wheels off. One thing led to another and i decided to get the plumbing done on the rear corners as well. Tomorrow i will wire up the rest and also the tank pressure sensor as well.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Rear plumbing done, heres how she sits for the night :)
Posted Image
  • Who's Online   0 Members, 0 Anonymous, 2357 Guests (See full list)
