ok so i haev a 12" orion cobalt single 4ohm sub and a kicker cvr dual 4 ohm sub. is there any way i can wire the kicker at 2 ohms and the orion at 4? because i have a kenwood amp thatll put out 500 watts(max on orion) at 4 ohms and 900 watts(max on kicker) at 2 ohms
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
i know but its all i got to work with atm tell i get payed. then im getting another kicker
ok u said first off, now wheres the second and third and so on...
Edited by HotRodHam
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
does anyone know? cuz i rilly need help
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
so is this bad for ur subs? or ur amp
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
its bad for your subs one might not get enough juice and the other could get to much but it might be possible with like a 4 channel amp. and also if one is only holding 500 max and 900 max the max power is how much it can hold untill it blows.
Edited by kjj913
Veng.
Just run the kicker sub by itself, and you tried to do what you said, depending on how you connected them to the amp, which could be interesting, could cause one of the two subs to blow or the amp to just either, blow/go into protect mode/get very hot. Wire the dual 4 ohm sub in parallel so it is 2 ohm and wire that to the amp.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
ok so i just hooked em up and ima play em like this untell i get my new orion or kicker idk yet but either one will work
idc if i lose one of the subs cuz i still go the other one :)
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
