Why remove all that to test? Just remove the remote wire from the amp, get a short piece of wire and jump it from the remote turn on the amp to the 12 v+ on the amp, it should turn on, if it does then you know the remote wire is either not connected good or shorted to ground. Simple.
Do this! If the amp turns on then your wire is ran like shit or you popped the fuse again because of the wire being ran bad. Anything could punch it puncturing the the jacket and exposing the wire to metal. Your backseat could pinch it, door jam trim, dash trim, and so on. And if I were you I would run it on a toggle switch and IMO easier you could run the remote from the back if the radio. Although if you don't have a multimeter it's not the easiest to find which wire it is on the stock harness.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
heres back of amp .i run wire from remote to where ?
Get a piece of wire about 6 inches long and connect it from the remote terminal to the 12 volt power terminal, just touch it to it and the amp will come on if your power and ground are connected correctly!!!
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
Posted (edited)
remote goes from the 'REM' and jumps over to 'B+'. and ground the amp. it should turn on if it's not fried
EDIT: beat me to it :P
Edited by Torres
Ok amp works fine so it's either my remote cable or ground.also I have the loc just wired with my ground on back of hu, should I wire it in with my speakers if so which ones ? And where's the best place to ground the amp in the back of a tahoe
JUGGERNAUT DA ASSO
My last speaker amp had a very poor ground, and now there is no output :( good luck man.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I hooked it up ran remote to ign n we played with the ground n noticed that's where the problem laid. Im at work do I haven't regrounded it yet but besides that I went on this site n it said the speaker wires were tab n gray for left n dark green nnlight green for right. Spliced the loc with these wires. Now I have no sound
JUGGERNAUT DA ASSO
Where did you tap into the speaker wires at with the loc? Did you do it at the head unit or at a speaker?
Evo X build log
