remove the amp. leave the +, -, and remote wire on. Touch the + wire and the Remote to the + on the battery, and the - to the - on the battery. If the amp doesn't turn on its fried.
2006 Nissan Z Track.
My Feedback Thread
Why remove all that to test? Just remove the remote wire from the amp, get a short piece of wire and jump it from the remote turn on the amp to the 12 v+ on the amp, it should turn on, if it does then you know the remote wire is either not connected good or shorted to ground. Simple.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Or don't listen to what I told you. You should really make sure the amp even works before you go doing all the tedious work of rewiring every little wire. It will take about 2 minutes.
My Feedback Thread
Good point. But he still might have a bad ground or something wrong with the runs elsewhere.
My Feedback Thread
If it don't turn on, then check ground, if that is good, amp is fucked. Get another amp. Done!!!
Evo X build log
Sounds like you popped the fuse again. Check it with a test light or something.
Is it just me or does this thread somehow feel like a car-fire waiting to happen?
10.x volts fo' life!
