Fed a pair of 1/0 gauge wire through a factory grommet, NOISE through the gaping hole!
I have a 99 Nissan Frontier and I just ran new power wired through the factory wiring harness gasket (i had to snip the gasket to get the 1/0 in snug beside the factory wires.
Now I have road noise though this hole, and a little bit of air. It's SO annoying and I have no idea how to fill it back in.
Does anyone know of something I can pick up at home depot or advance auto parts so I can fill in the extra 'hole' I've made?
have you tried just taping around it with some duct tape? lol
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
expanding foam
R.I.P!
(Nov-29-2009)
92 explorer
current build
Just a thought stop by k-mart and get a small tube of silicone for like 5$ I Think. Its pretty rubbery so if you ever need to remove it you can and it drys kinda quick. Just an idea.
  • Who's Online   0 Members, 0 Anonymous, 3127 Guests (See full list)
