Redesigned box farther down, please check out both and tell me what you think
I'm pretty new at designing subwoofer boxes. I have built one and designed a couple. I came up with this design using Torres Box Tuning Calculator and wanted to get a more experienced opinion on it. I have calculated it to be about 3.97 cubes gross the box calculator says port displacement is .79 cubes (which I feel is a little high) and I guesstimated woofer displacement around .15 cubes cuz I couldn't find the actual number. This leaves me at 3.03 cubes net (3 cubes is the recommended for this driver). As for the port, it is 6.25 in x 6.25 in and I calculated it at 22.75 in long (after end correction). According to Torres this gives 39.06 sq in of port (it gives a range of 36-48 sq in) and 12.89 sq in of port area per foot and a tuning of 33.45 hz. I'm putting a pic below (measurements in pic are internal wood will be either 1" or 3/4") but does this look/sound like it would be a good box for daily SQL?
Edited by Coleslaw
Did you try a regular slot port as opposed to the square port with only 1 shared side?
It will give a bit more room to mount the sub and free up a hair more airspace.
Much simpler build too.
this. theres no real reason to make a square port like that unless theres just a certain look you're going for on the face of the box.
torres calulator already includes end correction.. no need to do it "Manually" lol, he told me himself.
I just don't know exactly how torres calc lays out the port and such so I just used it as a general base and did it myself from there. Torres shows 15.75" physical port length but I wasn't sure exactly how that was done.
Yea, I wanted to do a 3 common wall setup but I was having to make the port really long so I wasn't sure if I wanted to do it that way. I might try re-designing it that way. This isn't anything that is going to be done like this week, I'm just planning it out. It will prolly be built during christmas break when I am home from college since I don't have time to do it atm so I have plenty of time to play with ideas.
I know, like I said in the previous comment I might redesign with a 3 common wall setup. I just didn't at first because I was having to make the port so long to get the tuning I want.
K, New design, tell me what you think/which is better. I based the port length off "physical port length" in torres. Not sure if that is right but I don't really understand Torres (if anyone wants to explain that would be awesome XD).
much better
R.I.P!
(Nov-29-2009)
92 explorer
current build
