home-made port flares?
i want to add some flared ports to my next box, but no way im paying $5 a flare. I got to thinking, can i make a wooden mold for flaring ports? im thinking of buying a piece of 10x2 and getting it down to size for what i need. heres what im thinking of doing. get my circlejig and get 2 layers of 2x10 cut down to 9.5" circles, then glueing then together and putting an angle on it, depending on the ID of my local lowes's PVC. then cutting a 3rd circle and glueiing ontop of those, so say its a 3.85", 2" deep circle. then im gonna get about $10 worth of 80 (eighty, stupid emoticon.) grit and cram a router in the bottom of the whole think, then get the shape i want. when all is said and done, if it works, i will be making 1 piece or 2 piece ports, you cant find that anywhere. i will be selling em on here hella cheap if it works out. im starting with a flare for a 4" port, im sure this will end up getting revised.
what do you guys think??
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
i've seen these sorts of home made flaring jigs before
one guy used a single piece of PVC and a torch and slowly heated the pvc while applying some pressure on the other end of it (think putting yoru jig vertically on your table, putting the pipe on, then setting a weight on the other end)
worked great for him after a few failed attempts like the pipe splitting from too much pressure or too much heat.
yeah i can tell from my design the pvc most likely wont make it, maybe a 1x1 flare, i doubt pvc will go as wide as i want without problems. we will see tho!
wait, a torch!? no wonder he ruined it, im going to be using a heat gun. the torch is horrible, his split because he didnt get even heating, i might also make a coil that slides onto the pvc and heat it up with a model train actuator lol.
he only ruined about 3 pieces (and by ruin i mean he had to cut the cracked end off and start again 3 inches up) before he started getting them perfect every time.. and i'm pretty sure he had a fairly progressive flare on his as well. like 3" growing to 6"
man i had already skimmed that entire site by the time you posted that lol. it seems like what i should do actually, mold it with bondo. we will see tommorow if i can get my router table or drill press unburied.
My 2" port will have a 1" flare and my 4" and 6" will have a 1.5" flare, i will have to see about 8" and 10".
Lol, just save yourself 2 days of work and drop the $10... damn tightwad's these day!
how is it 2 days work? half a day at most, i may be an idiot, but im not an idiot.
besides, ports make awesome christmas presents
:lol:
I've read about heating the PVC and pushing it onto an upside down bowl.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
