OK I have got myself very confused over this one so maybe someone can shed some light on he situation for me.
When I turn the Ignition on in my car (not engine) my amp is coming on fine with no problem, but when I turn the engine on the amp goes into protect...
Now occasionally when I'm driving the amp will come on for anything from 2 seconds to the full journey but id say 90% of the time the engine is on the amp will be in protect.
I have used this exact same wiring on 4 other amps and it has worked perfectly every time including another of the exact same model.
Any ideas anyone?
Amp - Kicker 200.4
Power - 4ga from battery on 80A fuse reading 14+V on Meter
Ground - 4Ga onto bare metal chassis point
Remote - from HU 12+V
Live life to the full... Then TURN THAT BITCH UP!
get a DMM and check the remote wire voltage and supply voltage. Also try unhooking the RCA wires before cranking the engine. Try and narrow down where this is coming from.
isolate it. if you dont have a dmm you are really going to pull your hair out. id suspect the remote lead is funky. If everything checks out you might ahve a bad amp. somethign loose on teh board or what not
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
reading 12+ Volts from the remote and still getting problem without rcas
get 12 volts plus at the amp on power and remote? try it with RCAS plugged in and no speaker leads. Im thinking its the amp. Can you swap another one in?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I hope its not the amp just got it :(, reading 14+V on power and 12+V on remote, took out the remote and tried a bridge from the power input same problem. as for the speakers i still have to try that
well you just proved you are getting power to it. You've got a bad something somewhere.
problem with RCAs unhooked rules out the head unit and RCAs as a cause.
if it protects iwth the speakers unhooked it leaves the amp. You can double check all fuses as well.
You may have a loose speaker lead that is grounding out. That might explain why you get sound every once in a while. But if it protects iwth nothing hooked up thats not the case.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
issue still there?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2050 Guests (See full list)
