alright guess i have a clarion headunit and its been running fine for about 2 years now ive been wanting a volt me to check everything just to have to make it a little better in car shows
now ive been doing dumb posts and ive researched all night and picking my brain at this but heres what i did
i took a sunpro volt meter like this one http://www.buyscheaper.com/buy-cheap-sunpro-cp8215-styleline-voltmeter-black-dial-special-price/
and what i did was hook it up to the power and ground on my headunit using 18 gauge wire now while i was installing it and BEFORE i mounted it under my dash i went to test it and everything was great and nothing was going wrong then i put my headunit back in and bolted it back in place and checked it again and it worked great again
heres whats puzzling me after i screwed the mount in for some reason nothing works my headunit nor the volt meter will work and i have been picking my brain for the past 3 hours trying to figure this out someone please help cause show in 3 days and i need it working again even if the volt meter doesnt work i need my sound thanks
pull it back out and remove the meter and see if the hu comes back out, then post back.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i unhooked the volt meter and left the wires hanging there and it still doesnt work
Sounds like you grounded a power wire out and then possible blew a fuse or you have a loose connection.
Evo X build log
did you check all your fuses? lol
i checked the main fuse in the fuse box but i havent had a chance to check the one thats behind the headunit its midnight here so i was wearin down im waking up at 7 to check and go over everything
i pray to god its one of the last 2 u said cause i have fuses laying around all over the place and im just hoping the headunit didnt fry cause the car show has an audio competition section that im entering
There is only three wires that make a hu work, 12V constant(usually yellow), ignition(usually red), and ground(always black). You messed with two of the three and then it quit working, that is where I would start....LOL
Evo X build log
