I recently added two stiffening capacitors to two amps. They were wired the same. The wire from the battery to the positive terminal on one of the capacitors got extremely hot, caught fire, and burned up. NONE of the other wires were even warm, not even the one from the cap to the amp. Anyone have any idea why this one wire from the battery would burn up?
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
Too much current for the wire size. What size wire is it?
That's what i was thinking, but why only on one side? and it's 8 gauge wire.
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
the longest run burnt up because it has more resistance. the shorter runs (cap to amp) can handle a lot more current because they are shorter, less resistance.
no go put some proper fuses on that power wire before you burn your car down. upgrade it too. obviously 8awg isnt enough, and it hardly ever is.
You don't think 8 gauge is big enough for a 1/2 farad cap and a 1000 watt amp? and the same wire was powering the amp before I added the cap, but it was pulling pretty hard the electrical system, i figured it needed a cap...is it possible there's something wrong with the cap?
Edited by osamio
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
I'm running 8 gauge alone to my sub lol
so? for 1 8awg speaker wire is really overkill for you. and second, maybe he only has a 500w amp. granted it sounds like he has more than that but I'm sure he will be just fine with 4awg.
8 guage is ok for 1kw probably.
You might have hooked them up in series or something, or maybe you didnt tighten the wire onto the cap post well enough which caused a lot of resistance, no idea without some pictures and stuff really.
Hammerdown... 1%
1000 watts RMS or MAX? RMS you should probably upgrade to 4awg... should be fine if its 1000max/500rms.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
1000 max, but it is a pretty long wire run, so I ordered a 4awg wiring kit. should be good to go.
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
