Hello everyone. I'm using the RE box calculator to design a ported enclosure for my subwoofer. I know I want 29.25 total port length. After entering in all of my other dimensions, I played around with the numbers until I got this:
What I dont understand is how a 12.75" piece and a 12" piece make a 29.25" port length.
Calculated to inside: 12.75+12=24.75
Calculated to outside: 16+12+.75+2.5=31.25
Averaged: (24.75+31.25)/2=28
Middle of port: 12.75+1.25+12+1.25=27.25
If someone could please explain how this works to me it would be much appreciated.
you mesure it from the middle of the inside of the port like this...
http://s748.photobucket.com/albums/xx127/freshman69699/?action=view&current=newnewbox2-1.jpg
dont mind all the random shit i dident feel like croping it
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
That calculator is known to make mistakes when calculating L-shape ports. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
just for further clarity reasons, this is correct. measure all the way down the middle the port. lets say you have a 4" port. you draw an imaginary line that is 2" from both sides (essentially in the middle) all the way down to the end of the port
Torres box calc is better. His also gives you physical port length which is measured at the port wall so there is no guessing.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
I'm pretty sure it is. That's how I did mine (I also added in the 3/4" for the front baffle thickness).
Edited by R_Mac_1
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
because it's a bent port the length of the port is actually the average of the LONG side and the SHORT side together. which is the same as the measurement down the MIDDLE of the port.
And nice picture, freshman, wonder who made it :D
