Hello all, so my co-worker asked that i take a look at his viper 160xv remote start/car alarm system to see why that when he locks and unlocks his doors that it does not honk his horn like it used to. I know that you can do so in programming mode but when viper says to turn the key and press the vallet button, there is no vallet button. His remote antenna only has the antenna itself, no buttons built into it nor is there an emergency disable switch. does anybody on here know how to get into programming mode for this system so i can re-enable his horn honk feature that he wants when he locks and unlocks his doors?
Thanks again!!
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
last viper alarm i had installed they put the valet button by the fuse box, it was at best buy. you check to see there? hope that helps
Oh yea. I checked. Amd whoever installed his unit did a shitty ass job. The brain is right under his center console in plain sight and the wires are very easily accessable. I can't trace the switch anywhere
