Inside of enclosure????
AMI CUSTOMS
Install dependent.
Nothing changed but carpet on the box, box was mounted in the exact same spot, BUT that is either here nor there. Topic is about inside of enclosure, outside would be a different thread all together. SO.....more thoughts on inside of enclosure techniques to raise your score... Let's hear em!!!
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Install dependent says it all. Its not an extreme install or vehicle so the flex of the cab and compression of the carpet isnt going to change anything probably.
I second the "golf ball" point posted earlier.. told someone else to do that a while ago and its on my list of things to more extensive testing on (i've only done a quick test on a pre-fab box using a hand-made bit to make the dimples. Cant make the dimples too small I would think, but maybe its worth testing size of large vs small.. then you gotta sand all the ledges of the dimples....
Maybe it would be easier to try computer modeling this, then you can dry different dimple profiles without building 30 boxes lol.
Hammerdown... 1%
That would be a first for me ever hearing about this golf ball method, this is something I need to test in another environment before I go making a million dimples in my wall....LOL
Evo X build log
After 155/56, mechanics that normally applied to the double power/gaining 3 db NO LONGER APPLIES... Don't believe me, try it... Lol... Smoothing completely inside of your enclosure, can gain you anywhere from .3 - 3Db... See my enclosure? It's going to have the same surface as the outside of my vehicle... It'll get waxed too, just like the outside... Go over to TL and look at the thread about gaining dbs... Its really informative...
That is pretty interesting, I must have a unique setup cuz when I was doing 157's, I doubled power and did 160's all day long....interesting...LOL Thanks for the pointers.
Evo X build log
We already put a fog machine in the box and found the problem areas, there is only a few right by the port. But I have a fix for that.
It is funny you say carpet hurts alot, cuz just recently I had the same thought, but on this guys truck I built, it is an extended cab pickup similar to an s10, it is a Nissan something. Anyway, built his box two square 12's both firing up and port on driver side firing up. Metered it, did a 148.3, then a week later, carpeted the box in trunk liner, metered again, same number. Oh and didn't change an single thing other then carpeting the box. Explain that....
subs were broken in.
like what they did on mythbusters with the aerodynamics of a car and how the dimples improved it somehow
R.I.P!
(Nov-29-2009)
92 explorer
current build
Nope, he already had them in a different ported box with months of play time on them, he didn't like the way it sounded so he came to me. So there can be different theory's about it I guess, it was just strange to me that carpet vs no carpet it did same number exactly. But could be a few reasons, one being level of pressure wasn't that great....
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 592 Guests (See full list)
