P4Killer_'s first go at a 4th Order
what are the specs on your box ?? ratio and such?
Roughly with the 2x2's and woofer displacement accounted for its 2.6 cubes sealed, 1.6 ported with 2 4" ports @ ~57.6 Hz. Maybe down the line, Ill put more power too the subs, Id really like to see what happens then. For this little amp, at least to my ears, its kinda impressive :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
you got that all wrong... i just did a sketchup of what i'd do and came out with .9 sealed per sub with a 3-1 ratio bringing it to 2.7 cubes ported
so 1.8 cubes sealed and 5.4 cubes ported tuned to 48
so 7.2 cube box... big box
hell even covering up those ports and turning your ported area into sealed area might benefit you
R.I.P!
(Nov-29-2009)
92 explorer
current build
Covering my ports means dual sealed mean zero output. Im not a 4th order wizard by any means, but ill give you a pic of what I used
Setup:
Xs D3400/ Xs XP3000
So unless this entire calculator is backwards, its designed to spec
Setup:
Xs D3400/ Xs XP3000
i dont go off calculators like this i go off 2-1 3-1 4-1 ratio
(ported to sealed ratio) i like 3-1 myself but is often big 2-1 is good for daily where as 4-1 is real peaky ha
the bigger the ported area the more efficient the subs will be
as for what i said bout cover ports i meant
turn your ported area into the sealed area and the sealed area into the ported area
cover up the port holes and re-drill them on the old sealed side
R.I.P!
(Nov-29-2009)
92 explorer
current build
Im sure your're very knowledgable and all, but you are essentially saying what Ive learned is backward. Even in WiniSd it comes up with essentially the very same spec as far as the box goes. So maybe in awhile Ill do as you have suggessted, but until then, Id like to know why you have come to these conclusions. Or could you maybe offer your sources ie:. something to read in regards to theory. And although, in your opinion Ive built it backward, the output is decent given what it is and according to you, it would be better ie:. ill gain by simply reporting on the other side.. why? Ive no problem being corrected, but it will do me no help if I cant understand why.
Thanks alot for your help, and hopefully you can enlighten me
Setup:
Xs D3400/ Xs XP3000
As soon I read the specs I was like that's ass backwards.
I was like his numbers should e higher but I see why they aren't now. As stated id do around 1 - 1.5 sealed, and 2 - 3 ported with around 40 - 50 square inches of port tuned around 45 hz
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
But again the question is, WHY? If winisd and a few calcs online basically render the same reccomended specs, then why are they wrong>? knowledge was really the only goal is this project, and Id LOVE to learn as much as possible about this before working on a bigger scale. Its like letting someone else build for you, just because they did it for you and it pounds, means you yourself have learned nothing, and whats the point of that?
Setup:
Xs D3400/ Xs XP3000
i've talked to 80inches about bandpass's and learned alot from him
quote from 80 himself
well u usually do a 1:2 ratio for daily and if i can get a 1:4 ratio daily i will do it..cuz the bigger the ported chamber the more efficient the entire box is.
i cant provide sources but the way i learnt was getting basics down
people told me generally for an 18" sub you need roughly 1.75-2 cubes sealed for a 15 you need roughly 1.3-1.6 cubes sealed and for a 12 roughly .8-1.3 sealed
so i took those averages and played with them with different ratios and learnt from there
its hard to explain everything but generally the ported area should be bigger then sealed
and it should tuned roughly to 47-50 hz
R.I.P!
(Nov-29-2009)
92 explorer
current build
