Boon Posted November 17, 2010 Report Posted November 17, 2010 Hold the fuckin' phone guys. What size wire are you running, before you go and put a 200A fuse on it. If you get a high-ish resistance short in a length of shitty 4 gauge with a 200A fuse on it you're probably gonna have a car fire on your hands. 10.x volts fo' life!
horndawg Posted November 18, 2010 Author Report Posted November 18, 2010 Hold the fuckin' phone guys. What size wire are you running, before you go and put a 200A fuse on it. If you get a high-ish resistance short in a length of shitty 4 gauge with a 200A fuse on it you're probably gonna have a car fire on your hands. i am running 4 guage wire ... should i get bigger power wire and stay with the 100 amp inline fuse? or get bigger power wire and bigger inline fuse?
horndawg Posted November 18, 2010 Author Report Posted November 18, 2010 by the way, the boston has 4x25 fuses and the sundown has 3x20 fuses.
Socky Posted November 18, 2010 Report Posted November 18, 2010 I would run 1/0 with a 200 amp fuse, then get a distribution block in the rear for the 4 gauge, fuse before the block. 1 fuse in the front, 1 in the rear to be on the safe side. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
cubs_fan0718 Posted November 18, 2010 Report Posted November 18, 2010 Go with 0/1wire, get a 200amp ANL fuse and call it a day. Also when you upgrade ur wire u'll have it done for if you ever upgrade ur system. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
TorK102 Posted November 18, 2010 Report Posted November 18, 2010 Yeah man. Definitely 1/0 with a 200 anl fuse. And clean up your ground if you can. A better ground is imperitive My bass is louder than your mom... DC Level 4 15" with Level XL soft parts Planet Audio BB2400.1 Pioneer DEH-6000UB Head Unit 950 amp Kinetic Battery
bassl0va Posted November 19, 2010 Report Posted November 19, 2010 I would run 1/0 with a 200 amp fuse, then get a distribution block in the rear for the 4 gauge, fuse before the block. 1 fuse in the front, 1 in the rear to be on the safe side. Go with 0/1wire, get a 200amp ANL fuse and call it a day. Also when you upgrade ur wire u'll have it done for if you ever upgrade ur system. Yeah man. Definitely 1/0 with a 200 anl fuse. And clean up your ground if you can. A better ground is imperitive Why though? There is no point, He doesn't need 0g, and he sure as heck doesn't need 1/0g, that's just crazy. I like how every time someone asks a question about electrical everyone froths at the mouth and suggest 350 amp alternators and 3 batteries for a 1000 watt amp or something. The heck? It takes like 500 amps to blow a 200 amp fuse, and even that could take several seconds. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
horndawg Posted November 23, 2010 Author Report Posted November 23, 2010 i will probly just upgrade my inline fuse and see what happens
splwizard Posted November 23, 2010 Report Posted November 23, 2010 i got a 250 amp fuse on 1/0 wire but when i had 4g i was using a 150 amp fuse and was fine. and just to be safe i added a dist. block with 2 100amp fuses 1999 Taurus SE Power Acousticks Mofo-15 Crunch pzi 3000.1d Rockford Fosgate Prime 150.2d Alpine type S 6x8's Stinger 1/0awg wire
horndawg Posted December 6, 2010 Author Report Posted December 6, 2010 can anyone help me find a good anl fuse holder with fuse? looked on ebay and there are tons of them...
