how would i know if my battery's are bad
and when i first got my car 2 to 3 weeks later my stock battery died on me
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
also fyi to peeps.. i never had to calibarte my meter.. i check with dmm and it was reading exactly what my meter said.. bought it bnib too. :shrug:
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
  • 1 month later...
Well I bought a high output I just gotta have someone put it in but I unhooked the battery's in the trunk charged
them individually they charged them both charged less then a hour one got 13 volts then the other 12.9 then hours later one at 12.5 the other 12.6 then my battery under the hood 12.3
mids/highs
equalizer clarion
crossover interfire
t spec rca
seems like you have a parasitic load or something. that would sure explain how your stock battery died so fast and how you think your current ones may be dying. no you dont need a battery isolator unless you want your alternator to die off faster and unless you play your system with the car off for extended periods of time.
What's a parasitic load
mids/highs
equalizer clarion
crossover interfire
t spec rca
Maybe a silly question, but it seems you guys are only interrested in the V...
How do you guys measure the A ?
Or to make it a bit more difficult, How do you measure the CCA?
And i am not talking about the avarage stock battery (since we are all into caraudio)....
(for example: 12V, 100A, 3500CCA)
I am curious! :popcorn:
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
if i recall correctly you put a clamp meter on the + wire when the car is off and check for excessive current draw. sorry but i totally forget what the "safe" amount of draw is.
  • Who's Online   0 Members, 0 Anonymous, 2127 Guests (See full list)
