Alternator Whine in speakers
I got my blown sub back and put it back into the wall and started the truck up and began to go for a drive to start to break the sub in. Well I noticed between songs that I have alt whine in the speakers, turn the head unit off and it goes away. I have never noticed it before so it is really weird. Anyway, I have quad alt setup, each alt has ground and power 0 gauge going to the rear batteries. Also I noticed that if I turn the sub amps off or the 4 channel off I still get the whine, no volume, but if I turn the head unit off it goes away. What should I do?
My thoughts is upgrade ground on head unit to like 10 gauge??? Discuss!!!!
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
check your rcas, check your grounds. last time that happened to me it was a ground
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
Ground your RCA's?
What? Are you saying I grounded my RCA's? No that didn't happen if you are.
Evo X build log
I am gonna completely unhook both amps and see if it is still there then I will know if it is ground or RCA. That is really the only too things it could be right? And ground at either amp or battery or head unit when you say check grounds? Where was your issue at, which ground?
Evo X build log
Normally it is just a grounding issue - the first thing to do is to run a jumper wire from your head unit ground to your battery - post. Check to see if it clears up. If that dosn't work, run a jumper ground from your battery to amp. Check again. If that dosn't work, slave in a new set of RCA's. check again... If that dosn't work, try grounding the outer conductor of the RCA's to your head unit chassis.. especially if it is a pioneer head unit..... Repost if none of that works.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
I will give that a shot when there is daylight. It is a kenwood deck and AQ 3500's strapped, and memphis 45.4 amps.
Evo X build log
No I meant ground your rca's.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Alright, it was bugging me that it has this issue so I went outside with flashlight and found this. If I remove the link RCA cable between the two strapped 3500's it goes away, All I have to do is unhook the slave end and sound gone. How do I fix it, just replace that one coax video cable with another one? I am open to suggestions. Thanks
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
