email this guy
Nightmare Audio
will he/she give me a decent price on the box?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
whats with the precise ass dimensions? just go by .25 jumps.
u right it would be easy well what do you guys think will be a good start 13height 26 length 18length i believe
Edited by KnockinthaStreetzof608
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
why is your width 28.9? just make it 29. same with port height and width, why not just make it 3.0 or 2.75. by the way you have absolutely no port area. look at the port area and port area range. see something wrong?
I've used him when I get too busy and have multiple enclosures to build. Great stuff and I think he charged like $5 or $10 per design. Good guy and great designs. My current build walling off my silverado was designed by him.
better???
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
you have managed to get even less port area...look at what i said. PORT AREA RANGE and PORT AREA. the 2 numbers on the bottom right side. put 2 and 2 together and make your ports bigger.
how much much bigger do you think i should make my ports???
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
i dont know, put 11.75 for height (keep it that way) and play with the width and length till you get a number for Port Area thats between the two numbers in the Port Area Range. simple as that. oh and btw put 3 for the # of common port walls
I would go back to where you got the calculator and reread the post on how it works and what to do. After that read it 5 more times and you will understand it. Then come back if you still have questions. And read the whole thread not just the first post.
my 2 cents.....
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
