yes i agree on the 3500.1's!!!!!!!
and no the 90 wouldnt work.... we removed my hose and it was still hitting the plastic nipple that the hose goes on??? im clueless?? like i said id love to do the quads
Then get a different brake master, done. LOL
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i was running dual mechman 270s charging six XS D3100s powering three RF T4000s, a T800.4 and a T600.4 with minimal drops below 14v at full tilt for extended periods. no longer isolated the charging systems, and am now using triple mechman 270s charging an XS S1200 under the hood, same six XS D3100s powering same amps with voltage sitting at 14.5 at full tilt no matter how long i slam on the system. im running close to 15,000 watts with 0 issues dual or triple setup. i upgraded the triple because i plan on adding some more power...
I see AQ3500's in your future!!!! :popcorn:
Ha ha ha, stop taking the fun out of it. Lol, I'm planning on upgrading now the three T4000s for three AQ3500s....wall off with three 15" Mayhems...then add three more....ha ha ha. Cats out now.
But to the topic...you are more than fine with triple alt setup. You're going to need batteries anyways. How much room do you have?
Yeah that brake master is freaking huge, it be hydro boost or something. Cuz here is a shot of my 01 GMC
Evo X build log
You know GM did switch all of the full size truck/suv's in 04-05 to the larger 15 inch rotors and bigger calipers, mine is 14 inch rotor, I guess they increased the size of the brake master as well.
Edited by AMI CUSTOMS
Evo X build log
ok so i need some opinons...
im not wanting to load up on batteries simply bc the only place its looking like i can fit them is 2 up front under the hood, and maybe 4 in the back under the amp rack or under the truck behind the bumper??? all XS D3100's
but im looking into T.C. triple bracket and 3 of mechman's SMD spec alts.. 320a+
im looking into how i can just change that output hose on my resivor on the brake booster, and then run a quad setup with 3- 320a, and 1 250a all running on my MLA i still have my quad mla from my last attempt at quads....
but would 4 or 5 d3100 and 3 300A+ alts be sufficiant???
for my ampperage im pulling?
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
I would honestly use 10 or 11 D3100s if you rev your RPM up to 2000 when you play at full tilt. 5 would work, but expect a significant amount of voltage drop.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I think you should be fine, should stay up in the mid 13's.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Well I can tell you that my two 3500's with my quad kit, 3(240) and (1)220 at idle if I play it at full tilt and really pull on the amps, I can get the voltage to drop to 12.8 for like a sec, but if I put my foot on the gas pedal and raise the rpms up to just 1000, no drop ever. And that is without my VCM, if I hook it my VCM it still drops, but for even a shorter amount of time. I am only running 2 3100's and a 3400 underhood.
I took a picture of my sister in laws 2006 pickup, and her master cylinder sits back plenty far enough that you would have the room no problem, so maybe get a master out of a pickup? Her truck is a 2006 silverado extended cab 2wd with 4.8 base model. SO not sure where this change over is, but her master cylinder has a different fill tank on top too. I can load a pic up later if you need it when I get back to the computer. Just let me know.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 704 Guests (See full list)
