just let me know the ohm load of the driver/s you want the crossover to support, band pass, narrow band pass, low pass, or high pass, wether you want (-6db, -12db, or -16db slope) and the frequency you want to cross at, i will make a diagram for you in paint and PM it to you, but requests go in this thread. lets start with one i did for an example.
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Interesting stuff. Where do you get your capacitors from? I've been having trouble trying to find ~400 and ~300 microfarad non-polarized capacitors to build my own bass blockers.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
parts express man. you want to check the power rating on them before you buy tho.
400
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=027-376
320
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=027-372
500
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=027-378
what would you block with those? its like 50-65 hz on an 8 ohm load.
mids huh? lol.
bumping out of boredom. if you're getting some speakers on black friday a crossover is a must! just supply the info above :3
400
320
500
mids huh? lol.
Different impedance loads will have different cutoff frequencies.
For instance, with 4 ohm loads
a 200 microfarad cuts at 200Hz
a 320 would be about 150Hz
a 400 will cut out at 100Hz
and a 500 would be around 75Hz.
Thanks for the links.
Edited by lAutruche
My Saab 9000 build
Can you explain the difference between bandpass and narrow bandpass? Thanks dude, this thread brought up a topic I've been wanting to learn more about for some time.
1989 Chevy Caprice Classic
350ci V8 High Performance
JVC Arsenal HU
JL XR series components
Infinity Reference 6x9s
Pioneer Premier 4-Channel
Clarion 2-Channel
Rockford Fosgate Series 1 2-Channel
Fusion 2000.1D
MTX Crossover
RF, Knu, Kicker, and Monster wiring
NVX VCW 12in. Sub **Won on here from the Sonic contest!**
*Build log coming soon!*
Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
bandpass has a slope going up, its flat for a bit, and then drops back off, a narrow bandpass is a small certain range of frequencies then sharp drop offs.
i just went to the12volt one night and messed with crossover values on the calculator, turns out this stuff is easy as dirt to learn.
