Hey guys, new to the forum and wanted to start by asking a quick question. Ive done all the calculations and im pretty sure my set up will work, but i just wanted to run it by some more people. I will be going with 2 10w3v3 JL subs with an MTX JH1200 amp. the amp will give me 800watts at 2ohms rms. i want to know if a 4guage input will be enough. it accepts 1/0 guage but i already have some 4guage laying around to use. I have a speaker amp that Ill be giving 4guage already so I will go 1/0 guage to a distributer block to 4guage. Do you think that the amp will require more??
You should be good with 4ga
stevemeadedesigns.com/board/topic/1005-wirefuse-guide/
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
If its OFC Copper wire, 4gauge should handle 150amps of current. As long as the amps draw is less than that you should be ok. I don't think an 800 watt amp would take that much.
97 Maxima SE
Bunch of shit going in, check out the build
just use 1/0 gauge. i dont know why a 1200rms amp needs 1/0 gauge (might be cause its so fucking inefficient, i dont know) but i wouldnt take the risk. i have a feeling you will get mixed opinions on this.
edit: damn double ninja'd.
Edited by Kranny
if it has inputs for it, theres a reason. :clapping:
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If there's no possibility of you ever wiring the amp down to 1 ohm ever, then you'll be fine using 4ga. But if there's any possibility that you'd at some point want to get the max power out of that amp @ 1 ohm then you might as well bite the bullet and use the largest wire the amp will accept.
Edited by SQMonte
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
sorry for not replying guys, i got busy. im using two 4ohm subs single coil so the load will be 2ohm. and the rms from 2ohm is 800w. i asked MTX themselves and they said that the max amp draw is around 80amps. so i figure 4AWG should be fine. thanks for the insight :)
i think the 1/0 guage is just for looks or for those who want to go into 1ohm.
its not for looks lol. they have the 1/0 gauge inputs for a reason
alright alright, ill take your word for it ;) I just dont like ponying up haha. considering the fact that im getting a $500+ amp for only 250 I guess I can dish out a bit extra for some 1/0 guage wire. im recieving a Kinetik 2400 battery too (practically new from my brother for free). I just need to find the best solution for wiring it all up. my speaker amp takes 8 guage.. (will probally use 4guage cut at ends to fit...) so ill probally end up just running the wires straight from the battery to the amps instead of using a distributer block.
Why not run less of the expensive stuff and use a distributor block to branch into the cheaper wire? I mean $5-$50 for a distributor is not much. It will make the system a lot better and it won't be ghetto like you plan on doing it.
If it's worth doing, it's worth doing RIGHT
http://picclick.com/Amazon/Electronics-Computers-Photo/Accessories-Supplies/Car-Electronics-Accessories/Amplifier-Installation/Power-Distribution-Components/
i suck men dry...email me for details
  • Who's Online   0 Members, 0 Anonymous, 8723 Guests (See full list)
