norcal colby Posted November 28, 2010 Report Share Posted November 28, 2010 Hey guys, new to the forum and wanted to start by asking a quick question. Ive done all the calculations and im pretty sure my set up will work, but i just wanted to run it by some more people. I will be going with 2 10w3v3 JL subs with an MTX JH1200 amp. the amp will give me 800watts at 2ohms rms. i want to know if a 4guage input will be enough. it accepts 1/0 guage but i already have some 4guage laying around to use. I have a speaker amp that Ill be giving 4guage already so I will go 1/0 guage to a distributer block to 4guage. Do you think that the amp will require more?? Quote Link to comment Share on other sites More sharing options...
hdorre Posted November 28, 2010 Report Share Posted November 28, 2010 You should be good with 4ga stevemeadedesigns.com/board/topic/1005-wirefuse-guide/ Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
bobonit Posted November 28, 2010 Report Share Posted November 28, 2010 Hey guys, new to the forum and wanted to start by asking a quick question. Ive done all the calculations and im pretty sure my set up will work, but i just wanted to run it by some more people. I will be going with 2 10w3v3 JL subs with an MTX JH1200 amp. the amp will give me 800watts at 2ohms rms. i want to know if a 4guage input will be enough. it accepts 1/0 guage but i already have some 4guage laying around to use. I have a speaker amp that Ill be giving 4guage already so I will go 1/0 guage to a distributer block to 4guage. Do you think that the amp will require more?? If its OFC Copper wire, 4gauge should handle 150amps of current. As long as the amps draw is less than that you should be ok. I don't think an 800 watt amp would take that much. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2010 Report Share Posted November 28, 2010 (edited) just use 1/0 gauge. i dont know why a 1200rms amp needs 1/0 gauge (might be cause its so fucking inefficient, i dont know) but i wouldnt take the risk. i have a feeling you will get mixed opinions on this. edit: damn double ninja'd. Edited November 28, 2010 by Kranny Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 28, 2010 Report Share Posted November 28, 2010 if it has inputs for it, theres a reason. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
SQMonte Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) If there's no possibility of you ever wiring the amp down to 1 ohm ever, then you'll be fine using 4ga. But if there's any possibility that you'd at some point want to get the max power out of that amp @ 1 ohm then you might as well bite the bullet and use the largest wire the amp will accept. Edited November 29, 2010 by SQMonte Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f Link to comment Share on other sites More sharing options...
norcal colby Posted December 5, 2010 Author Report Share Posted December 5, 2010 sorry for not replying guys, i got busy. im using two 4ohm subs single coil so the load will be 2ohm. and the rms from 2ohm is 800w. i asked MTX themselves and they said that the max amp draw is around 80amps. so i figure 4AWG should be fine. thanks for the insight i think the 1/0 guage is just for looks or for those who want to go into 1ohm. Quote Link to comment Share on other sites More sharing options...
Loudcivic Posted December 5, 2010 Report Share Posted December 5, 2010 its not for looks lol. they have the 1/0 gauge inputs for a reason Quote 2015 silverado crew cab nothing atm but soon... Link to comment Share on other sites More sharing options...
norcal colby Posted December 6, 2010 Author Report Share Posted December 6, 2010 its not for looks lol. they have the 1/0 gauge inputs for a reason alright alright, ill take your word for it I just dont like ponying up haha. considering the fact that im getting a $500+ amp for only 250 I guess I can dish out a bit extra for some 1/0 guage wire. im recieving a Kinetik 2400 battery too (practically new from my brother for free). I just need to find the best solution for wiring it all up. my speaker amp takes 8 guage.. (will probally use 4guage cut at ends to fit...) so ill probally end up just running the wires straight from the battery to the amps instead of using a distributer block. Quote Link to comment Share on other sites More sharing options...
casemods Posted December 6, 2010 Report Share Posted December 6, 2010 my speaker amp takes 8 guage.. (will probally use 4guage cut at ends to fit...) so ill probally end up just running the wires straight from the battery to the amps instead of using a distributer block. Why not run less of the expensive stuff and use a distributor block to branch into the cheaper wire? I mean $5-$50 for a distributor is not much. It will make the system a lot better and it won't be ghetto like you plan on doing it. If it's worth doing, it's worth doing RIGHT http://picclick.com/Amazon/Electronics-Computers-Photo/Accessories-Supplies/Car-Electronics-Accessories/Amplifier-Installation/Power-Distribution-Components/ Quote i suck men dry...email me for details Link to comment Share on other sites More sharing options...
