Incin Posted November 28, 2010 Report Posted November 28, 2010 Alright the vehicle is a 99 Grand Am GT with stock electrical. Im going to be running a Fi BL 15 in a box tuned to 32Hz running off of a AQ1200D. My question is do you guys have any suggestions on what else I should get? To run it with the best outcome. well, it'll make you shit bricks.
thebiggmann12 Posted November 28, 2010 Report Posted November 28, 2010 second batt, or badass front batt, but if i recall correctly, u don't have room for a big front batt. get a good secondary batt, and do ur big 3. keep ur voltage up.
Incin Posted November 28, 2010 Author Report Posted November 28, 2010 How do I run a second batt? I honestly dont know. well, it'll make you shit bricks.
Alex K Posted November 28, 2010 Report Posted November 28, 2010 just run a + wire to both terminals, and same with - terminals. Fuse the + run at both ends 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
Playa Named Joe Posted November 28, 2010 Report Posted November 28, 2010 I ran my Rockford T1000 put out close to 1500 rms off all stock and never had a problem with voltage. But a second battery in the trunk would do good. Maybe Kinetik HC800 or 1400? 1994 Pontiac Grand Prix build
Rockbrook Posted November 28, 2010 Report Posted November 28, 2010 I ran my Rockford T1000 put out close to 1500 rms off all stock and never had a problem with voltage. But a second battery in the trunk would do good. Maybe Kinetik HC800 or 1400? damn so no Big 3? what was your Alternator's Stock Amperage? im just curious
Mosin Posted November 28, 2010 Report Posted November 28, 2010 I ran my Rockford T1000 put out close to 1500 rms off all stock and never had a problem with voltage. But a second battery in the trunk would do good. Maybe Kinetik HC800 or 1400? That depends on the kinda vehicle being used. Like the size of the alt, etc.. Some cars have a 60amp alt and others have 120's. Derp.
Incin Posted November 28, 2010 Author Report Posted November 28, 2010 Sounds good guys now let me run this by yall. I added all these to my list, KHC 1800 for batt, DB Link 0 gauge amp wire kit, and 20 ft of Monster 1/0 to do big 3 and run the second batt. Sound good or would I need more? well, it'll make you shit bricks.
menace to soberiety Posted November 28, 2010 Report Posted November 28, 2010 i put a vr1000 and a ppi pcx 12" in my girls kia. set up at 570 watts @2ohms. the stock alt is 120 amp. true 4 gauge ran to the amp. when the volume is 24 of 35 the bass hits and the car will jolt/ slow down because of the alt keeping up. the alt has no problem of keeping up. the reason it slows down is because of the wiring its only 8 gauge from the alt and all battery connections are a weak 8 gauge, first do a big 3. if you still experience a voltage drop then a second batt, agm type where you can locate it near an amp. also since batteries charge slow. i would recommend a cap AFTER the second batt. but only use a cap after the upgrades. big3,alt if needed, second batt then a cap. a cap has no place in a car without the proper set up.
