bcpballer64 Posted December 1, 2010 Report Posted December 1, 2010 This morning while getting ready I thought to myself, "Why couldn't I make a homemade cold air intake?" and I have a few questions about cold air intakes. Also I saw this (below) online and wondered what it was worth and would it work well? -E-Ram air. ($25.00)(Homemade) I went to a marine supply store and bought a 4" 230 CFM 12 volt DelMar Bilge Blower. I used 4" to 3" PVC reducing couplings to make it fit. ($2.50 from Home Depot)I installed it in my intake with a switch in my door panel. When I flip the switch alot of extra cold air is pushed into my intake. A 2.5 liter engine naturally consumes 86 CFM (Cubic Feet per Minute) in 5th gear going 65 mph. So that means that I'm pushing 8 PSI (Pounds Per Square Inch) 1. Could there be any harm caused by installing either? 2. Can I install both? Finally, anyone with experience at this that has made one have any tips or tricks? Oh, and my car is a 1986 Pontiac 6000 w/ 2.5L 4cyl, it is an automatic. It is slow as shit and I am looking for a little extra punch. Edit: This is the link to the page I pulled that info from if anyone cares to read it. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
PUNKYOU007 Posted December 1, 2010 Report Posted December 1, 2010 I have seen homemade intakes before. Most of them look homemade but other than that I would say they work just fine...better than stock. Not sure about the blower issue. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
Jbabycsx Posted December 1, 2010 Report Posted December 1, 2010 As far as an intake goes you should be able to find everything you need to build it at a hardware store. As for the home made blower, it wont work. Your car being an 86 probly runs on a speed density air/fuel set up and the system wont allow the fuel to be adjusted to the extra air being pushed in. In other words your car wont know that extra air is even being pushed into the engine so it will not add fuel to make the air/fuel ratio correct. Without doing that the car will run lean and no power will be made, possibly even lost power will be the result. 2000 GMC Sonoma AQ20 FTMFW! 4 DC XL 15's Cadence ZRS-C9 Infiniti Kappa 3.5's and 6x8's Bravox 6.5 components
bcpballer64 Posted December 1, 2010 Author Report Posted December 1, 2010 Ok guys sounds great. Looks like i may be making a trip to the hardware store this weekend any tips on the homemade cai tho? "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
tristan560 Posted December 1, 2010 Report Posted December 1, 2010 K&N 7" cone at advance auto for about 40ish...4inch dryer vent tubing, and hose clamps. Depending on how your throttle body is set up, just run it into your fender for a cheep fenderwell intake. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
bcpballer64 Posted December 2, 2010 Author Report Posted December 2, 2010 K&N 7" cone at advance auto for about 40ish...4inch dryer vent tubing, and hose clamps. Depending on how your throttle body is set up, just run it into your fender for a cheep fenderwell intake. I have been looking at some Spectre 10" cone on eBay and ya im gonna get some black pvc tubing from local auto store. i appreciate the advice. i was thinking about going behind the grill with it so i dont have to cut into my fender wells (they are metal) "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
tristan560 Posted December 2, 2010 Report Posted December 2, 2010 That'd work too....just grab some aluminum and make a heatshield with it. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
bcpballer64 Posted December 2, 2010 Author Report Posted December 2, 2010 That'd work too....just grab some aluminum and make a heatshield with it. Yeppers this should turn out quite well. in the future i will need to replace my exhaust (has a big hole in the pipe) and im thinking of replacing cat and back so that should help too. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
nautical7 Posted December 2, 2010 Report Posted December 2, 2010 Some people also use exhaust piping as well. It's fairly simple though just plan it out in advance of how you want to route the piping and you should be good.
PUNKYOU007 Posted December 2, 2010 Report Posted December 2, 2010 I know on my truck all i did was whats referred to as the "Swiss Cheese Mod" Google it, it might work for you too. I know it works on a few different vehicles all depends on how the intake is set up. Its free too. Well unless you wanna drop in a K&N filter. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
