It's getting hot ? So, it's working !!!:yahoo:
Hot like you can't touch it ?
If it has a problem it will cut, like Jacob (sundownz) told you.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
If signal goes in the amp is still making voltage -- this can actually damage the output section as it can climb too high with no load.
Good to know, I figured without a load connected and no current on the outputs it wouldn't be producing any wattage/heat. I learn something new every day.
97 Maxima SE
Bunch of shit going in, check out the build
If the amp is not shutting off it's fine -- it is not unusual for a high powered amp that is putting out high power to be warm :)
the man was spoken. I dont think you'll need more info than that
yes he has and thats is the most valued answer. hes says its fine its fine and i can no longer worry =]
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
Well a heat sink is made for a reason.. I mean if you don't expect something to heat up that is drawing more current than your house in a footprint the size of a skateboard, your nuts. If you think its the ground which can help contribute to it add some more runs to it. Or find a better spot.
Edited by Eric B
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
