New Shop Progress
kingsuv
To the point where i need to rebuild the conference table. Stacked all the router lifts to the side for tear down
3 years worth of build up.
about a dozen pencils were found total
Tore down the fence to center it more in the table.
Gave the table saw 14" more of fall off for larger cuts.
Working now on getting the 5 different blast gates in, without too much kink in the line with 4" pipe. 3" Y's down to what will be 8 router lifts total. Quite a few times laying everything out. Need another trip to the store.
Did you make your fence, or did you buy it?
I want to make a built in similar to what you're doing. But I only have 1 router. But I can't really afford to shell out $300 for a new fence set up. I was looking to build one maybe.
Looks good!
The fence and rail is Biesemeyer. Was a good 600 bucks when I got it 10+ years ago. They can be had way cheaper now. Mine is the 50" model
Been slow going on this part. This last week has had me pulled away from the shop.
3 of the 5 Ivac auto blast gates are in. Tight fit doesn't even begin to describe what we have going here. 1 gate for the tablesaw, then the other 4 are for the 8 router lifts. each gate gets split off for 2 routers each.
Next up is the Rapid air system in the table. All 4 sides will have a pair of air drops. This allows me to have air line connections even when I don't have the overhead drops in place. Wiring up everything will take some time. Need power for the blast gate, and the tool connection. Then I need to wire in all the safety paddle switches. Oh.... and add in some power outlets for the use of hand power tools as well. Tricky part is making sure everything I add in is out of the way of the catch buckets for the router lifts which I can't put in till last. It's a good amount of assembly, check, and dis-assembly.
Nothing like using the old table top to support the new top. Little sketchy not having anything screwed down.
Part of the rebuild was to center the table. When I built this way back, everyone had their saw as far to the left as possible. After dealing with too much wood overhanging the left side, I finally realized that it was a dumb idea, and needed more table for the support.
Cutting full sheets by myself is no problem now.
Routers are better spaced out now as well. It's easier to work around one that needs to stay set during the fab process. Saves time not needing to reset bit height when doing detail work.
The safety switches are in and wired. Power goes into the switch then sent out to the outlet for the tool to be connected.
Split out the outlets so each side is connected to it's own safety switch.
Last part of this is to install the catch cans for the routers. Used 10" form tubes. Simple, cheap, light, and the inside is coated smooth. used a 2" port adapter cut into the bottom edge. 1/4" wood to seal the bottom.
Then some flex tube to tie it all in. 2 routers per gate. Plenty of suction split between the 2.
1st half of the table set and ready to suck.
Still need to order up the last of the Ivac gates and router lifts for the other half of the table. All the hard parts are in and ready for them.
Man, that looks freaking badass, I'm sure it's functionality is even better.
As simple as it is, there is a lot going on in the table. And for the rest of the collection system, I kinda went full retard in the build. Spent way more than I should putting it together. In all reality, it's something you won't give a 2nd thought too in a couple weeks and won't remember how you lived without it. Sure is nice to have a good 95% less mess to clean up at the end of the day.
In this hobby I've come to realize when there is a budget for something, write it down on a piece of paper. Take that paper and crumble it and throw it away because it's pointless lol. Especially if it's for yourself haha
Team Bass-Hz
