Im kinda new to the loud system scene lol. I know how to hook everything up but I just dont know all the specs as far as wat the best amp is and ohms and all that shit. But when taxes come this yr. i wanna get 2 18" sundown audio subs. This is the specs: # RE: 3.69 ohms
# Fs: 30.21 Hz
# Qes: 0.477
# Qms: 7.65
# Qts: 0.44
# Le: 2.62 mH
# Vas: 126.61 L
# BL: 24.21 NA
# Cms: 69.35 uM/N
# Mms: 400 grams
# Sens: 90.47 dB 1w/1m
I dont know about any of this stuff lol. Which is better 2 ohm or 4 ohm....?
And wat amp would best power these? :noob:
JENSEN 7" FLIP OUT H/U
*2 5 1/4 PIONEER DOOR SPEAKERS
*4 PLANET AUDIO TWEETERS
*2 6X9 PIONEER SPEAKERS
*2 12 POWERBASS 3XL'S
3000 WATT POWERBASS AMP
what amp? no idea. what power handling? no idea. you didnt give any info on the model number. also what vehicle are these going in?
Putting it in a 99 tahoe.
Subs: Sundown Audio Z v2 18" Sub woofer, come in either 1 ohm or 2 ohm
Amp: Sundown Audio SAZ-3500D
Specs:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $1549 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
7000W x 1CH
----RMS power, 1 ohm mono
3500W x 1CH
----RMS power, 2 ohm mono 1750W x 1CH
----RMS power, 4 ohm mono
750W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm <0.1%
Efficiency @ 4 ohm 86%
Fuse rating 300A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 53(H) x 660(L)mm
I see magic smoke in the future.
2006 Nissan Z Track.
My Feedback Thread
lol ya im gonna need alot of it.
hmm... i will go with crescendo amps...worked better for my(then sold:()
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
You guys don't know how hard I laughed at his response. Magic smoke isn't a good thing haha
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
have you any experience with subwoofars/amps/stereos/remotes?
do you plan on upgrading alternators and adding batteries?
lol well i thought it was. i guess not......
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
