I've got no audio on my laptop, whats going on here? I see the 15's and 18's are in seperate boxes. How is this thing tuned, and whose is it?
Yes they are indifferent boxes, 18s play below 38 and 15s play above 38(I think) and its TechForce's
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
the 18's are tuned to 28 hz and the 15s are tuned to something higher maybe 40??
the 18's have 1 AQ 2200 each and play like 38 and below
the 15's have a AQ 3500 and play above 38
this thing is fucking nasty. it had me shivering from the sheer air movement. the lows it can hit are just amazing. it really is a great setup
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
and everyone always says NO never mix match woofers it will cause phasing issues and cancellation, :) it that what you have? it doesnt look like it to me. the 15s do seem to move a lil more. hmmmm mite start a new trend. i remember back in highschool ( mid 80s) yea im old. a guy had 2-15s 2-12s and 2-10s in a lil civic 2 door was pretty loud
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Way I see it, if it setup that way, it just giving each set a band to play, which makes it fine to me.
Can't see videos, I'm using a mobile to view the forum and it won't show them.
exactly. he has it set up exactly like an active component set, just in the bass octaves
here are some links
http://www.youtube.com/watch?v=SZ0W6dz5zvA&feature=player_embedded
http://www.youtube.com/watch?v=dsjy0320eHw&feature=player_embedded
http://www.youtube.com/watch?v=UXNDFQZ2prI&feature=player_embedded
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
